I purchased 2 of these 1 channel modules and cannot get them to work with NCD-MCP3425. Please see screenshots
Look forward to receiving a solution
I will recommend doing an i2c. If the devices show up in that, that indicate issue with node red not with hardware
The device can be seen
I am using the NCD-MCP3425 node, Node-red v3.0.1, node -v16.16.0, npm -v8.11.0
Can you recommend a fix for this? I have to somehow get the sensor analog voltage into a Node-Red flow.
Thank you
