I’m new to NCD + IFTTT products and I currently can not flash MCP23008 using “build.particle.io/build ”.The board is a MCP23008 SCIO4R4G5LE (4 relay board + Particle), I followed this link:
[https://shop.controleverything.com/products/4-channel-relay-controller-particle-photon ](http://Tutorial for setting up MCP23008 SCIO4R4G5LE)
When click flash at the top left corner I get this message: “The server failed to process the request on time. Please try again”. Below is a short clip I recorded:
https://youtu.be/yCerwkShn3U
How Do I flash it?
THX!
jacob
November 11, 2019, 3:56pm
#2
Hi Happy,
This issue sounds more like a Particle error, you might check on their boards. Here’s a post they have with users reporting similar issues: https://community.particle.io/t/the-server-has-failed-to-process-the-request-on-time/40292/13
I also looked at actual downtimes for their build server and didn’t see one since 2014.
Did you change any part of the sample code? Our in-house Particle developer will be in tomorrow he may have more information for you.
Hi Jacob,
Thanks for replying.
I connected to another pc and it is working now!.
Now will need to get Node red started!
thx!
