Manual static IP to Gate way and SSH details
Dear NCD
We are planning to install the Gateway Lite on an Ubuntu Linux 24.04 LTS server. Kindly advise whether the Gateway Lite is compatible with Ubuntu Linux 24.04 LTS.
We would also like to manually assign the following static network configuration to the Gateway:
  • IP Address: 192.168.1.239
  • Subnet Mask: 255.255.255.0
  • Default Gateway: 192.168.1.99
  • Preferred DNS: 8.8.8.8
Kindly advise us on the procedure to manually configure the above IP settings.
Additionally, please provide the SSH access details/instructions for the Gateway Lite , including the required username, port, and authentication method, so that our team can access and configure the device remotely
Yes, you can assign a static IP to the Lite Gateway.
I’m not sure what you mean by install the Lite Gateway on Ubuntu. Do you mean you want to connect the Lite Gateway to an Ubuntu server? If so then yes, this is possible.
I would very highly recommend you look at the Atrium Gateway here however:
