I am looking into the Industrial Wireless Absolute & Gauge Pressure Sensor With 1/4 NPT to use to monitor the pressure of a fire sprinkler system within a large building, I was wondering 1. How does the wireless system works and 2. How does labview works 3. Can I just buy this one item or are there other things required.
Do I need wifi for it to connect to or does it work in some other way.
What is the difficulty level in setting up the product and setting it up with labview?
The system works like this, there are two components. A. Sensor B. Gateway
Sensor collects the data and sends to gateway over a wireless link.
You will need only one gateway. it can talk to multiple sensors
we have few gateway options. if you have wifi you can use our MQTT gateway
As far the data viewing goes, wont recommend labview.
do you want to view data on a local PC or on cloud ?
