Just received a 12-Channel I2C 0-10V Analog to Digital board, I am testing it as per this video (which I know is the 4 channel board but seems similar enough)
Raspberry Pi MCP3428 I2C Analog to Digital Converter Python Tutorial - YouTube
I am using this code on a raspberry pi 2
# Distributed with a free-will license.
# Use it any way you want, profit or free, provided it fits in the licenses of its associated works.
# MCP3428
# This code is designed to work with the MCP3428_I2CADC I2C Mini Module available from ControlEverything.com.
# https://www.controleverything.com/content/Analog-Digital-Converters?sku=MCP3428_I2CADC#tabs-0-product_tabset-2
import smbus
import time
# Get I2C bus
bus = smbus.SMBus(1)
# MCP3428 address, 0x68(104)
# Send configuration command
# 0x10(16) Continuous conversion mode, Channel-1, 12-bit Resolution
bus.write_byte(0x68, 0x10)
# Read data back from 0x00(0), 2 bytes
# raw_adc MSB, raw_adc LSB
data = bus.read_i2c_block_data(0x68, 0x00, 2)
# Convert the data to 12-bits
raw_adc = (data[0] & 0x0F) * 256 + data[1]
if raw_adc > 2047 :
raw_adc -= 4095
# Output data to screen
print ("Digital value of Analog Input on Channel-1: %d" %raw_adc)
# 0x30(48) Continuous conversion mode, Channel-2, 12-bit Resolution
bus.write_byte(0x68, 0x30)
if raw_adc > 2047 :
raw_adc -= 4095
print ("Digital value of Analog Input on Channel-2: %d" %raw_adc)
# 0x50(80) Continuous conversion mode, Channel-3, 12-bit Resolution
bus.write_byte(0x68, 0x50)
if raw_adc > 2047 :
raw_adc -= 4095
print ("Digital value of Analog Input on Channel-3: %d" %raw_adc)
# 0x70(112) Continuous conversion mode, Channel-4, 12-bit Resolution
bus.write_byte(0x68, 0x70)
if raw_adc > 2047 :
raw_adc -= 4095
print ("Digital value of Analog Input on Channel-4: %d" %raw_adc)
All the inputs are reading 1 where as in their demo they all read 0. When I do the battery test with AAA battery it stays at 1. What would I be doing wrong?
