Dear NCD Support Team,
I’m working with the NCD Industrial IoT Vibration Sensor V3 connected to an Enterprise IIoT Gateway. I’ve successfully utilized the sensor in both processed and processed with raw on-demand modes for several months. However, I’m facing errors when attempting to configure the sensor to raw data mode within Node-RED.
Error Description: After configuring for raw mode, the sensor indicates an error with two periodic LED blinks.
Steps I’ve Taken:
- I followed the guidance provided in your YouTube tutorial (https://www.youtube.com/watch?v=W9vNbxLZeq0&t=307s&ab_channel=NCD).
- I verified that the sensor is functioning correctly in the other two modes (processed and processed with raw on-demand).
Request: Could you please assist me with the following:
- Troubleshooting: Are there known issues or common configuration errors when switching to raw mode that I should be aware of?
- Log Analysis: Would it be helpful if I provide logs from the Enterprise IIoT Gateway or Node-RED to help diagnose the issue? If so, please let me know the best way to capture and share this information.
Additional Information of my sensor settings on Node Red:
Destination Address: (I have set it using the last 8 digits of the MAC Address provided by gateway as I hit configuration)
OTF: Enabled
Node ID: 0
Delay: 0
Retries: Disabled
Mode: RAW
Set On Request Timeout in seconds: Disabled
Set Sampling Duration: 40 (indicating 2secs)
Sampling Interval: 5 mins
Set RTC: Enabled
Low Pass Filter: Disabled
High Pass Filter: Disabled
Full Range Scale: +/-8g
Set Dead Band in mg: Disabled
Payload Length: 55 Bytes (I am using the sensor with 2.4ghz)
I need help on this issue asap. Please do instruct.
Kind regards,
Krish
