I have been having trouble connecting my Temp/Hum sensors to Ubidots, after following every resource I have been able to find on both the NCD and Ubidots website I am still unable to connect the sensors.
Below is the Node-Red flow that I have made to connect the sensors to Ubidots.
I think the problem may lie in the function node or possibly the switch.
Note: I have removed the authentication tokens but those are correct on my version. I have done tests to confirm that the setup of the Ubidots out node is correct.
[{“id”:“6916e621.e57ba8”,“type”:“tab”,“label”:“Flow 1”,“disabled”:false,“info”:“”},{“id”:“90fbf011.afe89”,“type”:“ubidots_out”,“z”:“6916e621.e57ba8”,“name”:“Body Fuel”,“token”:“”,“label_device”:“”,“device_label”:“bodyfuel”,“tier”:“business”,“tls_checkbox”:true,“x”:840,“y”:500,“wires”:[]},{“id”:“c8adab0c.863478”,“type”:“switch”,“z”:“6916e621.e57ba8”,“name”:“Sensor Output Control”,“property”:“payload.addr”,“propertyType”:“msg”,“rules”:[{“t”:“eq”,“v”:“00:13:a2:00:41:f3:a7:b7”,“vt”:“str”},{“t”:“eq”,“v”:“”,“vt”:“str”},{“t”:“eq”,“v”:“”,“vt”:“str”},{“t”:“eq”,“v”:“”,“vt”:“str”},{“t”:“eq”,“v”:“”,“vt”:“str”},{“t”:“eq”,“v”:“”,“vt”:“str”},{“t”:“eq”,“v”:“”,“vt”:“str”}],“checkall”:“true”,“repair”:false,“outputs”:7,“x”:460,“y”:280,“wires”:[[“9c99efe0.9053c”,“baf98e3b.b3abc”],[],[],[],[],[],[]]},{“id”:“98da0a02.8a5788”,“type”:“ncd-gateway-node”,“z”:“6916e621.e57ba8”,“name”:“”,“connection”:“837142ce.132b28”,“unknown_devices”:false,“outputs”:1,“x”:170,“y”:300,“wires”:[[“4825ef17.df1c2”,“6c271b99.fe4bf4”]]},{“id”:“4825ef17.df1c2”,“type”:“debug”,“z”:“6916e621.e57ba8”,“name”:“”,“active”:false,“tosidebar”:true,“console”:false,“tostatus”:false,“complete”:“payload”,“x”:430,“y”:180,“wires”:[]},{“id”:“2d13dd2.f96bf22”,“type”:“ncd-wireless-node”,“z”:“6916e621.e57ba8”,“name”:“Temp/Hum1”,“connection”:“837142ce.132b28”,“config_comm”:“837142ce.132b28”,“addr”:“00:13:a2:00:41:f3:a7:b7”,“sensor_type”:“1”,“auto_config”:false,“on_the_fly_enable”:“”,“node_id_delay_active”:true,“node_id”:0,“delay”:“60”,“form_network”:“”,“destination_active”:“”,“destination”:“0000FFFF”,“power_active”:“”,“power”:4,“retries_active”:“”,“retries”:10,“pan_id_active”:“”,“pan_id”:“7FFF”,“change_enabled”:“”,“change_pr”:“0”,“change_interval”:“0”,“cm_calibration”:“60.6”,“bp_altitude”:“0”,“bp_pressure”:“0”,“bp_temp_prec”:“0”,“bp_press_prec”:“0”,“amgt_accel”:“0”,“amgt_mag”:“0”,“amgt_gyro”:“0”,“impact_accel”:“0”,“impact_data_rate”:“4”,“impact_threshold”:25,“impact_duration”:1,“activ_interr_x”:1,“activ_interr_y”:2,“activ_interr_z”:4,“activ_interr_op”:8,“force_calibration_co2_auto_config”:“”,“force_calibration_co2”:400,“filtering”:0,“data_rate”:5,“time_series”:0,“reading_type”:1,“mode_80_active”:“”,“mode_80”:0,“measurement_mode_80_active”:“”,“measurement_mode_80”:0,“on_request_timeout_80_active”:“”,“on_request_timeout_80”:1,“deadband_80_active”:“”,“deadband_80”:0,“filter_80_active”:“”,“filter_80”:0,“output_data_rate_p1_81_active”:“”,“output_data_rate_p1_81”:0,“output_data_rate_p2_81_active”:“”,“output_data_rate_p2_81”:0,“sampling_duration_p1_81_active”:“”,“sampling_duration_p1_81”:0,“sampling_duration_p2_81_active”:“”,“sampling_duration_p2_81”:0,“led_alert_mode_84_active”:“”,“led_alert_mode_84”:0,“led_accelerometer_threshold_84_active”:“”,“led_accelerometer_threshold_84”:“”,“led_velocity_threshold_84_active”:“”,“led_velocity_threshold_84”:“”,“acceleration_interrupt_threshold_84_active”:“”,“acceleration_interrupt_threshold_84”:“”,“set_rtc_101”:0,“current_calibration_82”:“”,“current_calibration_82_active”:false,“current_calibration_c1_80”:178,“current_calibration_c1_80_active”:“”,“current_calibration_c2_80”:178,“current_calibration_c2_80_active”:“”,“current_calibration_c3_80”:178,“current_calibration_c3_80_active”:“”,“output_data_rate_101_active”:“”,“output_data_rate_101”:0,“output_data_rate_101_m2_active”:“”,“output_data_rate_101_m2”:0,“sampling_duration_101_active”:“”,“sampling_duration_101”:1,“sampling_interval_101_active”:“”,“sampling_interval_101”:1,“full_scale_range_101_active”:“”,“full_scale_range_101”:1,“full_scale_range_101_m2_active”:“”,“full_scale_range_101_m2”:1,“x_axis_101”:“”,“y_axis_101”:“”,“z_axis_101”:“”,“low_pass_filter_80_active”:“”,“low_pass_filter_80”:0,“high_pass_filter_80_active”:“”,“high_pass_filter_80”:0,“low_pass_filter_81_p2_active”:“”,“low_pass_filter_81_p2”:0,“high_pass_filter_81_p2_active”:“”,“high_pass_filter_81_p2”:0,“x”:130,“y”:140,“wires”:[[]]},{“id”:“9c99efe0.9053c”,“type”:“ui_gauge”,“z”:“6916e621.e57ba8”,“name”:“”,“group”:“e39490e1.d8282”,“order”:0,“width”:0,“height”:0,“gtype”:“gage”,“title”:“Temperature”,“label”:“Celcius”,“format”:“{{payload.sensor_data.temperature}}”,“min”:“-40”,“max”:“100”,“colors”:[“#00b500”,“#e6e600”,“#ca3838”],“seg1”:“”,“seg2”:“”,“x”:790,“y”:140,“wires”:[]},{“id”:“baf98e3b.b3abc”,“type”:“ui_gauge”,“z”:“6916e621.e57ba8”,“name”:“”,“group”:“e39490e1.d8282”,“order”:0,“width”:0,“height”:0,“gtype”:“gage”,“title”:“Humidity”,“label”:“Humidity”,“format”:“{{payload.sensor_data.humidity}}”,“min”:“0”,“max”:“100”,“colors”:[“#00b500”,“#e6e600”,“#ca3838”],“seg1”:“”,“seg2”:“”,“x”:780,“y”:180,“wires”:[]},{“id”:“7c77c2a1.ac325c”,“type”:“function”,“z”:“6916e621.e57ba8”,“name”:“Change level”,“func”:“// var newObj = {}; \n// newObj.payload = msg.payload;\n\n// //newObj.payload.ubidotsDeviceLabel = msg.payload.addr; \n\n// newObj.payload.temperature = msg.payload.sensor_data.temperature;\n// newObj.payload.humidity = msg.payload.sensor_data.humidity; \n\n// delete newObj.sensor_data;\n\n// return newObj;”,“outputs”:1,“noerr”:0,“x”:650,“y”:460,“wires”:[[“90fbf011.afe89”,“5d9cfcb5.4c7e94”]]},{“id”:“83badf22.4c66”,“type”:“switch”,“z”:“6916e621.e57ba8”,“name”:“Temp/Hum1”,“property”:“payload.addr”,“propertyType”:“msg”,“rules”:[{“t”:“eq”,“v”:“00:13:a2:00:41:f3:a7:b7”,“vt”:“str”}],“checkall”:“true”,“repair”:false,“outputs”:1,“x”:430,“y”:440,“wires”:[[]]},{“id”:“9a74037d.58cca”,“type”:“ubidots_out”,“z”:“6916e621.e57ba8”,“name”:“Temp/Hum1”,“token”:“”,“label_device”:“”,“device_label”:“Temp/Hum1”,“tier”:“business”,“tls_checkbox”:true,“x”:850,“y”:340,“wires”:[]},{“id”:“6c271b99.fe4bf4”,“type”:“switch”,“z”:“6916e621.e57ba8”,“name”:“”,“property”:“payload”,“propertyType”:“msg”,“rules”:[{“t”:“eq”,“v”:“”,“vt”:“str”}],“checkall”:“true”,“repair”:false,“outputs”:1,“x”:410,“y”:380,“wires”:[[“7c77c2a1.ac325c”]]},{“id”:“5d9cfcb5.4c7e94”,“type”:“debug”,“z”:“6916e621.e57ba8”,“name”:“”,“active”:true,“tosidebar”:true,“console”:false,“tostatus”:false,“complete”:“false”,“x”:840,“y”:600,“wires”:[]},{“id”:“837142ce.132b28”,“type”:“ncd-gateway-config”,“z”:“”,“name”:“”,“comm_type”:“tcp”,“ip_address”:“”,“tcp_port”:“2101”,“port”:“/dev/ttyS1”,“baudRate”:“115200”,“pan_id”:“7FFF”,“rssi”:true},{“id”:“e39490e1.d8282”,“type”:“ui_group”,“z”:“”,“name”:“Cooler”,“tab”:“4efc529b.b0387c”,“order”:1,“disp”:true,“width”:“6”,“collapse”:false},{“id”:“4efc529b.b0387c”,“type”:“ui_tab”,“z”:“”,“name”:“Body Fuel”,“icon”:“dashboard”,“order”:1,“disabled”:false,“hidden”:false}]
