Is it possible to change MirXR2x0 Smart Mode relay poweroff time?
I’d like to use an MirXR2x0 in an interlock application and i’m wondering if the time it takes the relays to turn off in ‘Smart Mode’ can be reduced. for what i’m doing shorter is better, understanding there are probably practical limits. ideally a watchdog timer would check link status and turn the relays off if it didn’t get reset in time, but the ‘Smart Mode’ seems to do a similar thing.
is this an application type you guys have have looked at before? having a configurable watchdog timer could make these pretty attractive for remote interlock interfaces.
thanks,
-Andrew
The Mirror series doesn’t have a configurable timer and generally isn’t designed to be configured via software so adding this feature would be a fairly large change. Currently I don’t think we’re looking to change the firmware on this series.
