We need to set up a static IP. After configuring the device in this way, we click on “save configuration,” and the device connects to the SSID we configured, but it uses DHCP. If we don’t assign an IP through DHCP, it doesn’t work with the static IP configuration. When accessing the device via its web interface using the IP it obtained through DHCP, we can see that the device reverts to having DHCP enabled. We have tried restarting it and reloading the firmware, but the behavior remains the same.
Let me test this on a device here. I will get back with you soon.
