Hi !
I’m interested in this sensor: “Industrial Wireless Absolute & Gauge Pressure Sensor With 1/4 NPT - PR52-33P”.
Industrial Wireless IoT Absolute & Gauges Pressure Sensor With 1/4 NPT (ncd.io)
Before placing an order, I’d like to have the answer to the following questions:
What is the minimum configurable time between 2 readings?
Is there a mode where the data is read in real time (in ms) and a signal is emitted if the pressure read exceeds a certain threshold?
Could you explain the difference between “absolute pressure”, “gauge pressure” and “sealed gauge pressure”? Does this have any impact on the fluid whose pressure can be read? In our case, we want to read a high-pressure liquid.
Thank you
