I can see that the minimium transmission delay is 1 second.
Is there any other vibration sensors can can do better?
Thanks.
We dont have any sensors who can send real time data all the time.
this one can send time domain data if you looking for FFT.
It that case, I can only do 1 second interval. Then I will need an external power supply.
What is the power requirement for the Industrial vibration IOT sensor SKU: PR49-24E.
Is there are power supply I can order?
Thanks.
You can use any 5-12V DC power supply.
It will be great if we could use the https://store.ncd.io/product/industrial-iot-wireless-vibration-temperature-sensor/, but when I try to buy, it only support 900 or 868 Mhz wireless. We will need 2.4 Ghz version. It is possible to customize for 2.4 Ghz?
I am see that the https://store.ncd.io/product/industrial-wireless-usb-modem/ now has a option for 900MHz (Singapore) Long-Range Wireless Mesh XBee-Pro® Communications Module. So, can the https://store.ncd.io/product/industrial-iot-wireless-vibration-temperature-sensor/ use the 900MHz (Singapore) Long-Range Wireless Mesh XBee-Pro® Communications Module?
All sensors and modems can be bought with Singapore certified 900MHz modules.
Thank you so much for the advise. But the https://store.ncd.io/product/industrial-iot-wireless-vibration-temperature-sensor/ there is no option for 900MHz (Singapore) Long-Range Wireless Mesh XBee-Pro® Communications Module. Can we buy the with the 900MHz (North America) Long-Range Wireless Mesh XBee-Pro® Communications Module for Singapore use?
The Singapore option is available now.
