I have purchased an Industrial IoT Wireless to Ethernet Modem which I am using to interface with a few Industrial IoT Temperature/Humidity sensors. I would like to be able to pull the sensor data into PRTG, which typically manages devices that use SNMP, WMI, Flow, or IPFIX. I was wondering if this modem has SNMP support, and if so, which SNMP version it uses.
Thanks!
