Hello - I’m observing inconsistent behavior when monitoring vibrations with the Predictive Maintenance Sensor (PR55-20A). The sensor is used in conjunction with the Wireless Ethernet Modem (PR55-17B).
The unit was initially calibrated sitting on a desk, returning the following results in Node-Red:
So, before calibrating back on top of the refrigerator, I reset the sensor once again at my desk and monitored RMS values for a few minutes and then shook the sensor for a moment. It appears that the values do not seem to return to the initial readings at rest.
Currently I am observing data in Node-RED, is there an alternative method for observing these values (the product manual states “Currently Labview UI is not Available for this Sensor”, however all of the examples in the manual reference Labview)?
The sensor was taped to the table, calibrated and allowed to sit idle for a few minutes before shaking. Note the odd, yet consistent, spikes in the x-axis min and max readings:
