Hello NCD friends,
I have a client that would like to modify slightly the behavior of the following NCD IFTTT board:
Before tackling the work, I wanted to double-check the following:
Is the IFTTT firmware this one here: NCD1Relay?
Thanks a bunch!
Gustavo.
Hey Gustavo,
Hope you’re doing well.
Yes, that is the library, specifically the main application is the CloudControl Example here which runs on the IFTTT devices:
Thank you for the pointers, Travis!
Regards.
