My setup consists of an NCD5500 Ethernet Module connected to a Industrial High-Power Relay Controller 2-Channel + UXP Expansion Port,
which has a UXP 16-Channel 12-Bit Analog to Digital Converter Expansion Board connected to that.
I use NCD Config Tool v1.0.0.10 to upload my custom web page and I’ve updated the firmware to HRev2_NCD5500_Latest.bin, which I got from GitHub - ncd-io/ncd_Ethernet.
I am referencing AD1216 Quick Start Guide when constructing an API call to query the ADC device. I am attempting to read all 16 channels at a time, 12-Bit resolution, device 0. This is the code that am using to test the API call.
function get_all_adc_16_channel_12_bit_callback(event, kwargs = {}) {
console.log(event)
function get_all_adc_16_channel_12_bit(kwargs = {}) {
var cmd1 = wrap_api([254, 196]);
console.log("sending command: ", cmd1)
send_command(cmd1, kwargs)
<button class="button" onclick="get_all_adc_16_channel_12_bit({'callbacks': [get_all_adc_16_channel_12_bit_callback]});">Do it!</button>
I am getting a weird response back. The command sent was: [170, 2, 254, 196, 110] and the response back is: webiControl_Callback({“webiControlRespond”:“170,32,3,0,7,0,7,0,7,0,7,0,7,0,7,0::::::::::::::::::::::::::::::::”});. I seem to be getting a response that is incomplete. I see the 170 header and byte size 32, which I expect. But, after that I only see a response which byte size of 14. Is this a bug in the software or am I doing something wrong?
Any help would be appreciated!
Dalton
