one more thing… does it has any contact closure output. A lot of machines outputs a contacts closure output when the machine is running.
if it doesn’t then current monitor will be the best sensor.
i am looking for same application but i need something that use Sim card as there is no wifi access, so basically i need to know when the machine is “working” or “not-working” from Avery far place (another city). any recommendation please.
Hi Majj you will need some kind of a 3G/4G GPIO which will simply take the level from the machine either a current transformer or an output from a dry contact and send this as an actual packet using the cellular network and be displayed on a web based platform. We have actually done this for a few of our clients.
Let me know if you want detailed info
