Hi I recently got a Predictive Maintenance Sensor and an IoT Edge gateway Computer, and I would like to export the data to an Excel spreadsheet on a SD card, how do I find the directory or path the gateway assign to the external devices?
The drive should mount to:
/mnt/sda1
You can use the Terminal on the IoT Edge Computer to confirm.
I tried to confirm using the Terminal, but still doesn’t show anything up, does the SD needs a specific formatting?
i will recommend using a USB flash driver.
SD card drivers are not fully supported yet.
once you insert a usb flash drive it will mount at /mnt/
