I am using the " I2C Shield for Onion Omega with Ethernet Port" to connect an omega2 to my wired network. But if I configured the device like here https://docs.onion.io/omega2-docs/using-ethernet-expansion.html explained, the ethernet port will not work. What is the correct configuration and wiring to get the ethernet port up?
As an additional info, the led’s at the plug does not show anything. Should they? The lan cable is ok btw (often used by my laptop)
The LED on the port are not supported.
can you share a picture of the setup and i will recommend checkin with onion community as well. They have a lot more exp with onion.
Maybe the Ethernet port is not working with my switch? Bas Rijniersce at the end says “Working with ControlEverything on their unit” Maybe someone have infos about this problem and there are some incompatiblities with an omega2?
