The chip gets very hot to touch when running and sitting idle. Have you scene this before? Is it a potential mis-configuration? a process on the device that’s running in a loop?
It is normal for the device to be warm when running. However it should not get so hot that you cannot comfortably hold your finger on it, if you cannot comfortably hold your finger on it then there may be an issue.
