Newb here…this is an existing system, that I inherited. Original Invoice #23584 circa 2014
I am able to add on/off buttons to web-i. Question 1: Is there something more current I should be using (shows depreciated-works fine!)?
Currently there are 16 banks 8 relays each. It is setup now to have all on / all off. What we would like to do is divide it up into 2 sections. Where we can turn on/off “A” portion as well as turn on/off “B” portion. 1st problem being the current “A” sections is spread across 13 different banks, some have 4 relays on a bank, some 1, some 2 non sequential… “B” section would essentially the opposite. I can group bank 1 relays 4567 and send a command, that’s fine. But I’ve only got 8 buttons on web-i and looks like I could send 3 separate commands per button. I’d prefer not to have so many buttons.
For example:
Bank 1 - Relay 4 5 6 7
Bank 3 - Relay 2
Bank 10 - Relay 6 8
Bank 14 - Relay 1
etc…(19 total)
I’m just chasing rabbit holes at the moment so any help pointing me towards the right one would be appreciated.
