First question: Is this a correct statement: When first turning on the sensor, the first 30 minutes of the warm-up occurs and a IAQ baseline is established.
Second question: What happens to the heated sensor while the device is sleeping? Does it need to heat up each time before sending the next reading?
Third question: If I hit the ‘reset’ button on the sensor, does it cause a new 30 minute warm-up baseline to be established?
Last question: I have 30 sensors that have been running for about one month. Most are only sending the value ‘80’ for IAQ, and a few are sending ‘0’. They have never sent any other values. This doesn’t seem correct, what might be going on with these?
