paulbae
1
I’m trying to get some height dimensions of your relay boards and can not find this info on your site.
Part number ZUXPSR241DPDTPR
This one https://store.ncd.io/product/industrial-relay-controller-board-24-channel-dpdt-uxp-expansion-port/
Thank you
jacob
2
The board heights are as follows:
With Standard connectors: 33 mm
1 Amp with Pluggable Connectors: 31.5mm
3 or 5 Amp with Pluggable Connectors: 37.2mm
The ZUXPSR241DPDTPR is a 1 amp with standard connectors so it will be 33mm.
