Ultimately we would like an email in an inbox (or keyword in gmail calender) to trigger a momentary relay closure for 50msec or so. We need a loud buzzer to activate in a warehouse when things popup on google calendar.
We had all this working with a photon board using IFFFT that would trigger particle that would operate a photon board relay output. This worked fine from 2018 to present until particle was no longer supported. I have watched the migration video that shows particle to webhooks, but I can not open the old IFFFT app I created since it is no longer supported so I do not understand how to do it.
Is there a newer board I should buy that is easier to setup? Should I continue using the photon board? Is there a newer integration I should use instead of Iffft?
The board we have is PR16-8-10A and when we ordered it we told you to program the momentary output code. I think all I had to do in the IFFT was say “1on” or “momentary” or something similar.
Thanks you.
