Hi @papakpmartin Got it, thank you for the feedback! It looks like your setup is correct. Could you try importing this flow and testing it, please? Just make sure to select the correct serial port (/dev/ttyUSB0) in the Wireless Gateway node.
[{"id":"b8939b6d8dda5c38","type":"tab","label":"EndNode 4-20mA Input Example","disabled":false,"info":"","env":[]},{"id":"e748227717d1a963","type":"group","z":"b8939b6d8dda5c38","style":{"stroke":"#999999","stroke-opacity":"1","fill":"none","fill-opacity":"1","label":true,"label-position":"nw","color":"#a4a4a4"},"nodes":["9b482dfa51a27c65","c4122250458ad048","559cd5f599c3e3be"],"x":534,"y":299,"w":432,"h":242},{"id":"63130894d3a55fdb","type":"group","z":"b8939b6d8dda5c38","style":{"stroke":"#999999","stroke-opacity":"1","fill":"none","fill-opacity":"1","label":true,"label-position":"nw","color":"#a4a4a4"},"nodes":["6966003bfc36520b","f13dc22483fd2696"],"x":1014,"y":299,"w":472,"h":142},{"id":"f7dea52a82065166","type":"group","z":"b8939b6d8dda5c38","style":{"stroke":"#999999","stroke-opacity":"1","fill":"none","fill-opacity":"1","label":true,"label-position":"nw","color":"#a4a4a4"},"nodes":["466b5b61fa269d89","ce1f5a90e8af3f9c","1936a330c5307f7a"],"x":54,"y":299,"w":432,"h":142},{"id":"6966003bfc36520b","type":"ncd-gateway-node","z":"b8939b6d8dda5c38","g":"63130894d3a55fdb","name":"","connection":"","unknown_devices":true,"outputs":2,"x":1150,"y":400,"wires":[["e3df83fd38dbf123"],["e3df83fd38dbf123"]]},{"id":"466b5b61fa269d89","type":"function","z":"b8939b6d8dda5c38","g":"f7dea52a82065166","name":"Set C1 4mA Cmd","func":"msg.payload = {};\nmsg.payload.data = [0xAA, 0x05, 0x35, 0x06, 0x01, 0x04, 0x00, 0xEF];\n// msg.payload.address = \"00:13:a2:00:41:db:8c:15\";\nreturn msg;","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":370,"y":400,"wires":[["c4122250458ad048"]]},{"id":"ce1f5a90e8af3f9c","type":"inject","z":"b8939b6d8dda5c38","g":"f7dea52a82065166","name":"Read","props":[],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":150,"y":400,"wires":[["466b5b61fa269d89"]]},{"id":"9b482dfa51a27c65","type":"comment","z":"b8939b6d8dda5c38","g":"e748227717d1a963","name":"Change address to match your endnode controller","info":"","x":750,"y":340,"wires":[]},{"id":"c4122250458ad048","type":"change","z":"b8939b6d8dda5c38","g":"e748227717d1a963","name":"Assign Target","rules":[{"t":"set","p":"payload.address","pt":"msg","to":"00:13:a2:00:41:db:8c:15","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":640,"y":400,"wires":[["6966003bfc36520b","559cd5f599c3e3be"]]},{"id":"e3df83fd38dbf123","type":"debug","z":"b8939b6d8dda5c38","name":"debug 1","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1580,"y":400,"wires":[]},{"id":"f13dc22483fd2696","type":"comment","z":"b8939b6d8dda5c38","g":"63130894d3a55fdb","name":"Edit the Wireless Gateway to assign your serial device","info":"","x":1260,"y":340,"wires":[]},{"id":"1936a330c5307f7a","type":"comment","z":"b8939b6d8dda5c38","g":"f7dea52a82065166","name":"Read Inputs 1-4","info":"","x":160,"y":340,"wires":[]},{"id":"559cd5f599c3e3be","type":"debug","z":"b8939b6d8dda5c38","g":"e748227717d1a963","name":"endNode req payload","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":820,"y":500,"wires":[]}]
Please try this and share us your results.
Eduardo M.
