We’re evaluating the Gen4 vibration sensors for predictive maintenance on centrifugal pumps (~1,780 RPM, some on VFDs) in a below-grade plant room. Our data scientist has defined the data we need, and I’d appreciate guidance on a few points:
Capture length: for bearing analysis we need about 1 s of contiguous raw data at 25.6 kS/s on one radial axis (~26,000 samples), and longer at low VFD speeds. The current maximum of 8,192 samples gives 0.32 s. Is there any way to capture longer, or to buffer back-to-back captures on the sensor with no gaps?
Firmware calculations: would it be feasible to add kurtosis and band RMS (e.g. 1–6 kHz) to the processed data, through a firmware update or custom firmware?
Battery life: what battery life would you expect with processed data every 15 minutes plus 8 raw captures a day (8,192 samples at 25.6 kS/s, single axis)? Alternatively, could you share the Gen4 current and duration values for processed and raw transmissions, so we can use your battery calculator?
Anthony
