I am in the need to of the full formal documentation (datasheet and full command set) for:
Industrial Relay Controller 8-Channel SPDT
SKU: ZUXPR85PROXR
I am looking for a pdf like, similar to an engineering family reference manual or datasheet.
1.- I need to know how to identify the 4 relay vs the 8 relay by the EEPROM identification?.
2.- And also need to know what the timers will exactly do. (arguments and return description?).
The reason is that I need to add a safety check (redundancy). For example: Turn ON relay via command. Then start a timer in my own code, then on expiration of 10 seconds, it will turn OFF the relay via command, but also, I need to start a timer inside the relay controller firmware, so the relay firmware turns itself back to off in 10 seconds (redundancy). This is in case the computer gets a blue screen and no longer can turn off relays.
I work for a company as firmware engineer. Personally I like how they have tutorials and tons of quickstart guides. These work great for the younglings that are getting into this. (they even have libraries to help you out do thigs quick). But professionally, all that info is not helping. I need the bare metal so I have full control of the project, not to mention the company project codebase is confined to its own rules and regulations, I cant simply add a third party library like the quickstarts suggest.
Therefore we use are own virtual comm port driver to do exactly and only what is needed. Which I need a reason I need engineering -like documentation. (huge pdf).
This product looks really good and I like the website, its clear they have invested a lot to make it user friendly, its full of DYI like examples for home or school project experiments.
But I just cant the find the right documentation that I need. I see snippets for some commands but wont cover for all questions I have.
Hope somebody can help.
Israel
