We have 3 sites in one building, each with NCD relays controlled by WIFI/network.
I would like to use a fob for toggle function.
The fob controller board cant go on the relays, as they have the wifi board on them.
I see different solution possibilities, but seeking most streamlined and failsafe.
I need 3 fobs to each be paired to one of 3 rooms and not interfere with each other.
SO I presume 3 receivers are needed; each fob and rx paired independent of the others.
But how to get receivers to be able to send a network command to LAN IP of relay…
Cheers from Iceland.
RP
