I have a GPI TM Series flowmeter (2in, TM Series (Water Meters) - FLOMEC) and I am considering adding their 4-20mA module (https://s3-us-west-2.amazonaws.com/catsy.467/4-20mA-module-owners-manual.pdf), which has both 4-20mA (flow rate) and pulse (volume, one pulse per gallon) capabilities. The pulses are Open Collector (NPN), Current Sinking.
I know NCD has this: https://store.ncd.io/product/iot-long-range-wireless-pulse-frequency-meter/ which would count pulses (if it can handle the above) and send them to a receiver, but I’m wondering how I can log the 4-20mA output at a certain frequency during each pumping session and send that to an Azure IoT db, say once per day, like at 3am when no one is there and we’re not pumping? Could I use a RPi and one of the 4-20mA Devices and a Shield? Is there a pulse-counting Device, so I can just have it all done by the RPi?
I have wifi/internet at the farm, and the flowmeter is <100ft away from one of the Ubiquiti mesh antennas. I can tap into the 220V circuit that drives the pump for power. I’d have a small battery to keep everything alive. This is in Belize, btw! I am in the US, but I want to build and test a solution before I head down there in a few months. I can’t test on that particular model of flowmeter, but I can probably fake up a proxy here using anything I can lay my hands on that produces a pulse, and anything else that cranks out 4-20mA.
