I am trying to order the " Solid State Relay Controller 2-Channel + 8 Channel ADC ProXR Lite - Type F - 3 Amp (For DC Loads) (UPC: 689860056305)" for my current project. Is a unique part ID number able to be generated for this board? Apparently my company does not use UPC codes as part numbers.
Will
Hi Will,
If you need to purchase one of these and need to send it to a purchasing agent then add the part with the options you need to your cart. Then in the cart you will find a Get Code button. That will generate a link you can share with the purchasing department/agent. If they click the link it will populate their cart with what you have and they can just go to check out.
If this isn’t the info you were looking for let me know.
