I recently purchased a 1-relay 5-amp ProXR Lite ethernet relay. I’m integrating it into a theater a/v installation to trigger a drop-down screen.
I’m able to trigger the relay using the NCD Base software. When I use our control software the “busy” light flashes briefly but the relay doesn’t trigger. So I know I’m sending the commands to the right place but I’m obviously making a mistake somewhere.
Hi Chris,
This command is correct, and should be the command you test with:
0xAA 0x03 0xFE 0x6C 0x01 0x18
Which of the Ethernet modules are you working with, we have 2 variations, look at the printing on the top, it will say either Lantronix XPort or Lantronix XPort Pro.
What software are you plugging the commands into? If it’s something like Crestron then you need to escape these bytes otherwise they are being sent to the controller as ASCII text which will not work.
