[{“id”:“3cbb48c8.f14478”,“type”:“tab”,“label”:“NCD ASSET MONITOR”,“disabled”:false,“info”:""},{“id”:“783b93f4.f58c8c”,“type”:“debug”,“z”:“3cbb48c8.f14478”,“name”:“1”,“active”:true,“tosidebar”:true,“console”:false,“tostatus”:false,“complete”:“true”,“targetType”:“full”,“x”:850,“y”:580,“wires”:[]},{“id”:“9c4bd8bc.91b378”,“type”:“ncd-wireless-node”,“z”:“3cbb48c8.f14478”,“name”:“ASSET”,“connection”:“333bdc31.cb3d54”,“config_comm”:"",“addr”:"",“sensor_type”:“25”,“auto_config”:false,“node_id”:0,“delay”:“1”,“destination”:“0000FFFF”,“power”:4,“retries”:10,“pan_id”:“7FFF”,“change_enabled”:"",“change_pr”:“0”,“change_interval”:“0”,“cm_calibration”:“60.6”,“bp_altitude”:“0”,“bp_pressure”:“0”,“bp_temp_prec”:“0”,“bp_press_prec”:“0”,“amgt_accel”:“0”,“amgt_mag”:“0”,“amgt_gyro”:“0”,“impact_accel”:“0”,“impact_data_rate”:“4”,“impact_threshold”:25,“impact_duration”:1,“activ_interr_x”:1,“activ_interr_y”:2,“activ_interr_z”:4,“activ_interr_op”:8,“filtering”:0,“data_rate”:5,“time_series”:0,“reading_type”:1,“x”:70,“y”:120,“wires”:[[“47acfe10.f69c7”,“bd4d7736.9d3978”,“6c2abcdf.d9c8f4”]]},{“id”:“47acfe10.f69c7”,“type”:“split”,“z”:“3cbb48c8.f14478”,“name”:"",“splt”:"\n",“spltType”:“str”,“arraySplt”:1,“arraySpltType”:“len”,“stream”:false,“addname”:“topic”,“x”:270,“y”:260,“wires”:[[“d933550b.e8c878”]]},{“id”:“7829af7b.41231”,“type”:“ui_chart”,“z”:“3cbb48c8.f14478”,“name”:"",“group”:“83eeae23.7a23”,“order”:3,“width”:0,“height”:0,“label”:“Desplazamiento en el tiempo”,“chartType”:“line”,“legend”:“true”,“xformat”:“auto”,“interpolate”:“bezier”,“nodata”:"",“dot”:false,“ymin”:"-1",“ymax”:“1”,“removeOlder”:“1”,“removeOlderPoints”:“20”,“removeOlderUnit”:“60”,“cutout”:0,“useOneColor”:false,“useUTC”:true,“colors”:["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],“useOldStyle”:false,“outputs”:1,“x”:980,“y”:220,“wires”:[[]]},{“id”:“3ab966bd.58bb7a”,“type”:“ui_gauge”,“z”:“3cbb48c8.f14478”,“name”:"",“group”:“771cbb69.47bf04”,“order”:1,“width”:0,“height”:0,“gtype”:“wave”,“title”:“Battery”,“label”:“V”,“format”:"{{value | number:2}}",“min”:0,“max”:“3.3”,“colors”:["#ff0011","#e6e600","#09ca00"],“seg1”:"",“seg2”:"",“x”:500,“y”:360,“wires”:[]},{“id”:“bd4d7736.9d3978”,“type”:“change”,“z”:“3cbb48c8.f14478”,“name”:"",“rules”:[{“t”:“set”,“p”:“payload”,“pt”:“msg”,“to”:“data.battery”,“tot”:“msg”}],“action”:"",“property”:"",“from”:"",“to”:"",“reg”:false,“x”:280,“y”:360,“wires”:[[“3ab966bd.58bb7a”]]},{“id”:“abbfd258.eb403”,“type”:“range”,“z”:“3cbb48c8.f14478”,“minin”:"-1000",“maxin”:“1000”,“minout”:"-1",“maxout”:“1”,“action”:“clamp”,“round”:false,“property”:“payload”,“name”:"",“x”:750,“y”:260,“wires”:[[“7829af7b.41231”,“5eddbee3.c691a”,“1ab8a7.5187475a”,“e7b4c962.305fe8”]]},{“id”:“5eddbee3.c691a”,“type”:“ui_chart”,“z”:“3cbb48c8.f14478”,“name”:"",“group”:“83eeae23.7a23”,“order”:2,“width”:0,“height”:0,“label”:“Ultimos valores”,“chartType”:“radar”,“legend”:“false”,“xformat”:“HH:mm:ss”,“interpolate”:“linear”,“nodata”:"",“dot”:false,“ymin”:"-3",“ymax”:“3”,“removeOlder”:1,“removeOlderPoints”:"",“removeOlderUnit”:“3600”,“cutout”:0,“useOneColor”:false,“useUTC”:false,“colors”:["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],“useOldStyle”:false,“outputs”:1,“x”:940,“y”:260,“wires”:[[]]},{“id”:“d933550b.e8c878”,“type”:“switch”,“z”:“3cbb48c8.f14478”,“name”:“Switch”,“property”:“payload”,“propertyType”:“msg”,“rules”:[{“t”:“index”,“v”:“0”,“vt”:“num”,“v2”:“2”,“v2t”:“num”}],“checkall”:“true”,“repair”:false,“outputs”:1,“x”:410,“y”:260,“wires”:[[“37b32063.1c487”]]},{“id”:“37b32063.1c487”,“type”:“change”,“z”:“3cbb48c8.f14478”,“name”:“Change”,“rules”:[{“t”:“change”,“p”:“topic”,“pt”:“msg”,“from”:“acc_x”,“fromt”:“str”,“to”:“x”,“tot”:“str”},{“t”:“change”,“p”:“topic”,“pt”:“msg”,“from”:“acc_y”,“fromt”:“str”,“to”:“y”,“tot”:“str”},{“t”:“change”,“p”:“topic”,“pt”:“msg”,“from”:“acc_z”,“fromt”:“str”,“to”:“z”,“tot”:“str”}],“action”:"",“property”:"",“from”:"",“to”:"",“reg”:false,“x”:580,“y”:260,“wires”:[[“abbfd258.eb403”]]},{“id”:“ff87af81.ec2dc”,“type”:“ui_gauge”,“z”:“3cbb48c8.f14478”,“name”:"",“group”:“beb05eeb.7a09b”,“order”:3,“width”:0,“height”:0,“gtype”:“gage”,“title”:“Y”,“label”:"",“format”:"{{value | number:2}}",“min”:"-1",“max”:“1”,“colors”:["#ff0011","#e6e600","#09ca00"],“seg1”:"",“seg2”:"",“x”:1090,“y”:340,“wires”:[]},{“id”:“af3553.4cca3ab”,“type”:“ui_gauge”,“z”:“3cbb48c8.f14478”,“name”:"",“group”:“beb05eeb.7a09b”,“order”:1,“width”:0,“height”:0,“gtype”:“gage”,“title”:“X”,“label”:"",“format”:"{{value | number:2}}",“min”:"-1",“max”:“1”,“colors”:["#ff0011","#e6e600","#09ca00"],“seg1”:"",“seg2”:"",“x”:1089,“y”:298,“wires”:[]},{“id”:“f73ef410.34e3a8”,“type”:“ui_gauge”,“z”:“3cbb48c8.f14478”,“name”:"",“group”:“beb05eeb.7a09b”,“order”:5,“width”:0,“height”:0,“gtype”:“gage”,“title”:“Z”,“label”:"",“format”:"{{value | number:2}}",“min”:"-1",“max”:“1”,“colors”:["#ff0011","#e6e600","#09ca00"],“seg1”:"",“seg2”:"",“x”:1089,“y”:378,“wires”:[]},{“id”:“1ab8a7.5187475a”,“type”:“switch”,“z”:“3cbb48c8.f14478”,“name”:“Switch”,“property”:“topic”,“propertyType”:“msg”,“rules”:[{“t”:“eq”,“v”:“x”,“vt”:“str”},{“t”:“eq”,“v”:“y”,“vt”:“str”},{“t”:“eq”,“v”:“z”,“vt”:“str”}],“checkall”:“true”,“repair”:false,“outputs”:3,“x”:910,“y”:340,“wires”:[[“af3553.4cca3ab”],[“ff87af81.ec2dc”],[“f73ef410.34e3a8”]]},{“id”:“865a0b1a.6ab0e8”,“type”:“ui_text”,“z”:“3cbb48c8.f14478”,“group”:“83eeae23.7a23”,“order”:1,“width”:0,“height”:0,“name”:“Texto”,“label”:“Medición de vibraciones en linea”,“format”:"{{msg.payload}}",“layout”:“row-left”,“x”:590,“y”:140,“wires”:[]},{“id”:“34f95de0.924982”,“type”:“mysql”,“z”:“3cbb48c8.f14478”,“mydb”:“f2996f09.3ef9d”,“name”:“mySQL”,“x”:1050,“y”:480,“wires”:[[]]},{“id”:“6c2abcdf.d9c8f4”,“type”:“change”,“z”:“3cbb48c8.f14478”,“name”:"",“rules”:[{“t”:“set”,“p”:“payload”,“pt”:“msg”,“to”:“data.received”,“tot”:“msg”}],“action”:"",“property”:"",“from”:"",“to”:"",“reg”:false,“x”:280,“y”:480,“wires”:[[“5a48d382.a4a77c”]]},{“id”:“1bd3c869.396248”,“type”:“debug”,“z”:“3cbb48c8.f14478”,“name”:“2”,“active”:true,“tosidebar”:true,“console”:false,“tostatus”:false,“complete”:“true”,“targetType”:“full”,“x”:1050,“y”:580,“wires”:[]},{“id”:“5a48d382.a4a77c”,“type”:“simpletime”,“z”:“3cbb48c8.f14478”,“name”:"",“x”:490,“y”:480,“wires”:[[“e7b4c962.305fe8”]]},{“id”:“26d1879b.c114b8”,“type”:“template”,“z”:“3cbb48c8.f14478”,“name”:“Format data”,“field”:“topic”,“fieldType”:“msg”,“format”:“handlebars”,“syntax”:“mustache”,“template”:“INSERT INTO datos (Fecha,x,y,z) VALUES ( utc_timestamp,’{{payload.x}}’,’{{payload.y}}’,’{{payload.z}}’)”,“output”:“str”,“x”:870,“y”:480,“wires”:[[“34f95de0.924982”,“1bd3c869.396248”]]},{“id”:“e7b4c962.305fe8”,“type”:“join”,“z”:“3cbb48c8.f14478”,“name”:"",“mode”:“custom”,“build”:“object”,“property”:“payload”,“propertyType”:“msg”,“key”:“topic”,“joiner”:"\n",“joinerType”:“str”,“accumulate”:false,“timeout”:"",“count”:"",“reduceRight”:false,“reduceExp”:"",“reduceInit”:"",“reduceInitType”:“num”,“reduceFixup”:"",“x”:710,“y”:480,“wires”:[[“26d1879b.c114b8”,“783b93f4.f58c8c”]]},{“id”:“66cecc21.1f66a4”,“type”:“template”,“z”:“3cbb48c8.f14478”,“name”:“Format data”,“field”:“topic”,“fieldType”:“msg”,“format”:“handlebars”,“syntax”:“mustache”,“template”:“INSERT INTO datos (Fecha,x,y,z) VALUES (’{{myyear}}-{{mymonthn}}-{{mydom}} {{mytimes}}’,’{{payload.x}}’,’{{payload.y}}’,’{{payload.z}}’)”,“output”:“str”,“x”:490,“y”:580,“wires”:[[]]},{“id”:“333bdc31.cb3d54”,“type”:“ncd-gateway-config”,“z”:"",“name”:“Serial_2”,“comm_type”:“serial”,“ip_address”:"",“tcp_port”:“2101”,“port”:“COM9”,“baudRate”:“115200”,“pan_id”:“7fff”,“rssi”:false},{“id”:“83eeae23.7a23”,“type”:“ui_group”,“z”:"",“name”:“Datos actuales”,“tab”:“b29efd05.0f84d”,“order”:1,“disp”:false,“width”:9,“collapse”:false},{“id”:“771cbb69.47bf04”,“type”:“ui_group”,“z”:"",“name”:“Estado”,“tab”:“b29efd05.0f84d”,“order”:3,“disp”:false,“width”:“4”,“collapse”:false},{“id”:“beb05eeb.7a09b”,“type”:“ui_group”,“z”:"",“name”:“Valores independientes”,“tab”:“b29efd05.0f84d”,“order”:2,“disp”:false,“width”:4,“collapse”:false},{“id”:“f2996f09.3ef9d”,“type”:“MySQLdatabase”,“z”:"",“name”:"",“host”:“localhost”,“port”:“3306”,“db”:“iot”,“tz”:""},{“id”:“b29efd05.0f84d”,“type”:“ui_tab”,“z”:"",“name”:“Monitor de activos”,“icon”:“dashboard”,“order”:1,“disabled”:false,“hidden”:false}]
