I’m trying to get raw vibration sensor data as continuously as possible in a node-red environment.
Right now, I got the min,max,rms data out of the sensor, but i want the time domain data transmission.
Seeing we implemented our system in node-red, is sending this command possible with the existing libraries?
We would need to do this continuously and at different sampling frequencies. Is there a way to do this with no human intervention (physically pressing the configure / reset buttons)?
Thanks for the reply. That’s the sensor I have, so I know it can send time domain data.
My questions were:
Is sending the “time domain data transmission” command possible in your node red libraries?
Is it possible to change the time domain data transmission sampling frequency without physically pressing the configure / reset buttons on the sensors?
In our invoice (number 46788) we have
PR52-33N Industrial IoT Wireless Vibration And Temperature Sensor, Rohs Compliant
Which corresponds to the SKU number for the sensor
hi,
i remember there was an instance where we talked to one of PWC engineer and we decided to go with low noise sensor and we also added one extra probe.
If you are looking into a sensor which can send time domain data then you will need PR52-33N. I wasn’t aware that time domain is a requirement. The one you have is PR52-33E.
I will have one PR52-33N ready for you.
for private discussion i can be reached at bhaskar@ncd.io.
