I’m trying to create shadow updates for my Enterprise IoT Gateway working with a 2-channel vibration sensor.
I followed the steps in the setup guide and the additional instructions you sent to help modify the tutorial for my type of sensor.
Right now, I am able to see that my gateway is connected to AWS and I can see it sending information to the correct topic. However, I haven’t been able to make a working classic shadow for the Enterprise yet.
I tried following the advice in the below linked thread:
I adjusted the message topic to send to the shadow update and I am now getting the same final error:
“code”: 400,
“message”: “Missing required node: state”
Because of the difference in sensors and gateways, I’m not sure how to fix this error with the Enterprise IoT. Is there a way to adjust the message format to work with the AWS format?
I’m not adjusting the payload from the default. That might be one of the sources of the problem I’m facing. Currently the payload looks like this from the node-red debug window:
Adjusting the JSON object format did the trick and I’m now getting the shadow updates and activity. The function node did the trick converting the message. For reference, I used this basic function layout:
Unrelated, but my 2-channel vibration sensor stopped sending information.
The LED began to blink 3 or 4 times in succession about every minute when it was supposed to send data. I turned it off and then turned it on again when I noticed the missing data, but now the LED never blinks, not even when I hit the reset button.
It was working fine earlier today but it started to give this odd result later in the day, and I really noticed it when I turned on another sensor. Did the LED’s blinking like that mean a certain status of the machine?
Hi @cshoerrner let me ask if your vibration sensor is powered by an external power supply or battery?
Based on the sensor data screenshot, I noticed the battery voltage is very low (~1.49V). If the battery voltage drops below approximately 2.8V, we recommend replacing the batteries.
Eduardo M.
Yep, it absolutely was the batteries that I had in the sensor. They just coincidentally died when I turned on the other sensor, so it looked like a weirder event than it was. I replaced the batteries and the two sensors are working fine now.
