We are building a software where we have a NCD Modem that listens to the different sensor readings when a “session” is running, so it does not need to constantly get the readings.
I would like to know if it is possible to dynamically (without entering configuration mode):
- lower the interval when we start the session,
- get an initial reading,
- higher the interval when we stop the session,
We receive the sensor reading as bytes with a TCP Client, is there a way to send to the server the same type of message to do the different actions listed above?
We are using the following sensors:
- Air Quality PR55-59_THPC
- Air Flow Velocity Sensor PR55-24B
- Door sensor PR55-1G_1S
Thank you for your time!
