We are using the vibration and temperature sensors and receiving data through the MQTT gateway. We are receiving duplicate data received in the Mosquitto broker as seen below. Not sure why this is happening.
{“00:13:A2:00:41:A8:5A:7C”:{“transmission_count”:113,“battery_level”:3.29406,“type”:8,“node_id”:1,“rssi”:100,“rms_x”:8.75,“rms_y”:1.26,“rms_z”:2.26,“max_x”:191.05,“max_y”:0,“max_z”:10.98,“min_x”:-13.9,“min_y”:-17.56,“min_z”:-15.37,“temperature”:25}}
{“00:13:A2:00:41:A8:60:6A”:{“transmission_count”:104,“battery_level”:3.29406,“type”:8,“node_id”:3,“rssi”:100,“rms_x”:46.17,“rms_y”:1.92,“rms_z”:2.74,“max_x”:183.73,“max_y”:13.17,“max_z”:16.83,“min_x”:-188.12,“min_y”:-10.24,“min_z”:-15.37,“temperature”:25}}
{“00:13:A2:00:41:A8:60:6A”:{“transmission_count”:105,“battery_level”:3.29406,“type”:8,“node_id”:3,“rssi”:100,“rms_x”:34.15,“rms_y”:2.1,“rms_z”:2.24,“max_x”:183.73,“max_y”:13.17,“max_z”:10.98,“min_x”:-188.12,“min_y”:-16.1,“min_z”:-15.37,“temperature”:25}}
{“00:13:A2:00:41:A8:60:6A”:{“transmission_count”:106,“battery_level”:3.29406,“type”:8,“node_id”:3,“rssi”:100,“rms_x”:48.47,“rms_y”:1.9,“rms_z”:2.51,“max_x”:183.73,“max_y”:10.24,“max_z”:13.9,“min_x”:-188.12,“min_y”:-13.17,“min_z”:-15.37,“temperature”:25}}
{“00:13:A2:00:41:A8:60:6A”:{“transmission_count”:107,“battery_level”:3.29406,“type”:8,“node_id”:3,“rssi”:100,“rms_x”:36.08,“rms_y”:1.96,“rms_z”:2.42,“max_x”:183.73,“max_y”:10.24,“max_z”:16.83,“min_x”:-188.12,“min_y”:-13.17,“min_z”:-18.29,“temperature”:25}}
{“00:13:A2:00:41:A8:60:87”:{“transmission_count”:112,“battery_level”:3.29406,“type”:8,“node_id”:2,“rssi”:100,“rms_x”:2.23,“rms_y”:1.04,“rms_z”:2.94,“max_x”:12.44,“max_y”:11.71,“max_z”:10.24,“min_x”:-10.98,“min_y”:-11.71,“min_z”:-16.1,“temperature”:24}}
{“00:13:A2:00:41:A8:60:87”:{“transmission_count”:113,“battery_level”:3.29406,“type”:8,“node_id”:2,“rssi”:100,“rms_x”:2.53,“rms_y”:1.48,“rms_z”:3.22,“max_x”:18.29,“max_y”:11.71,“max_z”:16.1,“min_x”:-13.9,“min_y”:-11.71,“min_z”:-16.1,“temperature”:24}}
{“00:13:A2:00:41:A8:5A:7C”:{“transmission_count”:114,“battery_level”:3.29406,“type”:8,“node_id”:1,“rssi”:100,“rms_x”:8.68,“rms_y”:1.11,“rms_z”:2.3,“max_x”:188.12,“max_y”:0,“max_z”:13.9,“min_x”:-13.9,“min_y”:-14.64,“min_z”:-15.37,“temperature”:25}}
{“00:13:A2:00:41:A8:60:6A”:{“transmission_count”:108,“battery_level”:3.29406,“type”:8,“node_id”:3,“rssi”:100,“rms_x”:40.44,“rms_y”:1.92,“rms_z”:2.19,“max_x”:183.73,“max_y”:10.24,“max_z”:10.98,“min_x”:-188.12,“min_y”:-13.17,“min_z”:-15.37,“temperature”:25}}
