Hi NCD team,
I am interested in the two 4-20 mA Loop Tranmsmitters, as shown below:
https://store.ncd.io/product/1-channel-isolated-4-20ma-current-loop-transmitter-with-power/
**https://store.ncd.io/product/1-channel-4-20ma-current-loop-transmitter-i2c-mini-module**/
I have some related questions:
1) In addition to the loop voltage that comes along with the 4-20mA 2-wire system, do the two modules need to be supplied with an additional (external) 5-V supply voltage ? Or it is sufficient to power both modules using the loop voltage (i.e., true 2-wire system) ?
2) Since I need to connect these 4-20 mA Tx modules with my sensor, do the two modules provide 5V supply voltage to power my sensor ? If yes, what is the maximum current the modules can supply ?
3) What are the main differences between the two modules ? I could see that one is written as “with power supply” and the other one is “mini module”.
Best regards and thank you very much !
doyoulinux
