I seem to have misplaced the DIN rail mount for the Enterprise gateway. Where can I procure another one of these dohickeys?
Those are provided by the Gateway manufacturer(Robustel) with the gateways. I don’t know where you could purchase them individually. The hole spacing of the screws is 15mm and most clips I’m seeing from other suppliers are 20mm.
Are you ordering anything in the near future? If so I could probably dig one out of a drawer and throw it in there for you.
Actually, I was wrong. The 0 point on my calipers was off. The hole spacing for the screws is 20mm so you can use this:
https://www.digikey.com/en/products/detail/recom-power/R-DR-CLIP/17801492?gclsrc=aw.ds&gad_source=1&gad_campaignid=20509822964&gbraid=0AAAAADrbLlgXQry4x2D6kzkm3fzA3JcCn&gclid=CjwKCAjwidXQBhAZEiwA4egw6M7aR_mNxPKiOJpWGEQxU98I3zN1SBquAa_FYf-Jv1TmPq-MvrfG3hoCwdcQAvD_BwE
Excellent!
I found a bunch of listings for these clips on Amazon too, I didn’t know they were so common.
Thank you Travis for the link and measurement confirmations, Much appreciated
Tim
