Digimesh Repeater
We have a transmitter in a closet that is a little far away from our nearest Robustel gateway. The data is coming in but it is a bit splotchy. I was thinking of using the NCD digimesh repeater to boost the signal strength. Should I place the repeater within the same closet as the transmitter, or place it strategically somewhere halfway between the transmitter and the nearest gateway?
Somewhere between the Gateway and the sensor would be ideal. You will not increase the range by placing it in the same closet as the sensor.
