Hi, I would like to know if I can get the wireless IoT Predictive Maintenance sensor with a pressure sensor instead of the ac current sensor. The pressure sensor would be inches of water and would measure 0-20" of H2O.
Yes, it can be done
- how many pcs do you need
- do you have any exp working ncd sensors
Hi
We plan to use it with our equipment we sell. www.sonicairsystems.com
For now we looking for a partner that can supply the equipment and looking for software where it is easy for our customers to look at the data.
I do not know how many pieces we will need as we are looking for a source first. We will also need to test the sensor to make sure it is what we need.
No, I do not have any experience working with NCD sensors.
for testing purposes, I will recommend getting off-the-shelf hardware
PM Sensor
Pressure sensor
Gateway
This will let you test out everything. once you have the setup working, we can build a custom PM sensor with a pressure sensor
Is there a phone app we can use to download the data?
no there is not any app
