IS there any protection in case of current overload on Solid State Relays (Type G 20Amp) ?
I would like to know the PROXR Fusion Behavior in a case the current is higher than specified.
thanks
Tomer
thanks
Tomer
Hi Tomer,
Drawing excessive current through the Solid State relay would most likely damage it if it were for an extended period of time. You can view the full specs of that relay here:
