Hi NCD,
I’d like to see if I might get a credit for returning a gently-used Azure Gateway in order #449326 so that I can use the credit toward purchasing the MQTT gateway. Seems that the MQTT Gateway with Ubidots is the solution for us.
I will be purchasing five MQTT micro gateways.
Thank you.
