I have installed NCD Base station and tried to configure and read data from 2-Channel AC Current monitoring sensor. I followed the instructions given in the document ZigBee_Mesh_Quick_Start_Guide for Base Station set up.
I followed step by step instructions in chapter 3 - setup. Till 4th step it is working fine. I can see “Your device is ready to use” dialog box. Then if I select the appropriate Com Port, Baud Rate and click OK, It shows “The controller did not respond to the baud rate you selected” and starts searching other baud rates, finally exits.
Intention is to read from the sensor using Xbee in both ports (I2C is a different discussion). It may be helpful even if I need to do it via XCTU if not in Base Station. (All XBee modules were in 115200. Then tried with 57600 and 9600 as well).
I tried the same with NCD Environmental sensor and got the same results. Tried with Xbee module alone without any sensors and got the same.
Xbee module details:
IC: 1846A-XB900HP
Model: XBee PROS3B
(I believe Base Station supports XB900 S3B)
Thanks in advance.
