Is it possible to copy a node-red flow from one IoT Edge Computer to another?
Yes, open Node-Red flow editor in your web browser. Click the Menu Button at the top and click export. Make sure it is set to output the flow. Save that to a file. Then on the other Edge Computer click the menu, then click import.
TravisE - I am familiar with Export/Import in Node-Red. However, on the Edge Computer, the only options I get are Export to Clipboard. Which is ok, as I can open a notepad session on my computer and save it. However, I do not know how to get it to the second Edge Computer to import it.
Thank you for your help. One of the edge computers allows import/export to library, for some reason, the other doesn’t allow export to library. But, I think I have a work around.
