I am trying to configure the contact closure to ethernet to access a web page when the sensor is triggered (different page for open/closed). I cannot seem to find the documentation on where the configuration is for what happens when the sensor is triggered.
Yes that’s the unit. Ok, what is the data that is sent to the UDP server that’s configured in the setup then for open and closed? If I can get it to s Nd that databto the required port I can modify the receiving server to accept that packet. Thanks.
It will send a byte array with an API wrapper that contains the prior state and the current state of all inputs. It does this using 1 byte for each using bitwise logic i.e. bit 1 of the current state byte indicates the state of input 1.
