Is this the device we would use for a repeater?
How do we configure it? I didn’t see any user manual in the ‘resources’ tab.
Yes it can be used as repeater.
All it needs is power and make sure has same network id.
Where/how do we set the network ID? Alpha station is not able to communicate with the modem via USB.
We have the modem connected via USB to the laptop. The radio button for USB is selected when Alpha Station loads, COM port confirmed in device manager, and baud is default at 115.2k. When clicking on ‘Sensor View & Setup’ the app responds 'Unable to Communicate with Modem"
use xctu to check the network id/pan id and it can be used to change the pan id as well
