I am having issues interpreting the reading I get from the current sensor on my Predictive Maintenance V3 sensor, the number I’m getting is in the hundreds, but I’m expecting amps. My flow is below, am I pulling the wrong number?
[{“id”:“3fb61b98.1eefbc”,“type”:“tab”,“label”:“PM Sensor”,“disabled”:false,“info”:“”},{“id”:“62f4b632.c050e”,“type”:“ncd-gateway-node”,“z”:“3fb61b98.1eefbc”,“name”:“Edge computer”,“connection”:“837142ce.132b28”,“unknown_devices”:0,“outputs”:1,“x”:500,“y”:300,“wires”:[[“24a2c41f.171a5c”]]},{“id”:“24a2c41f.171a5c”,“type”:“debug”,“z”:“3fb61b98.1eefbc”,“name”:“”,“active”:true,“tosidebar”:true,“console”:false,“tostatus”:false,“complete”:“true”,“x”:670,“y”:300,“wires”:[]},{“id”:“20ed2fc4.54cb6”,“type”:“ncd-wireless-node”,“z”:“3fb61b98.1eefbc”,“name”:“PM Sensor”,“connection”:“837142ce.132b28”,“config_comm”:“”,“addr”:“00:13:a2:00:41:ed:db:b6”,“sensor_type”:“82”,“auto_config”:true,“on_the_fly_enable”:true,“node_id_delay_active”:true,“node_id”:0,“delay”:“0”,“destination”:“0000FFFF”,“power_active”:“”,“power”:4,“retries_active”:“”,“retries”:10,“pan_id_active”:“”,“pan_id”:“7FFF”,“change_enabled”:“”,“change_pr”:“0”,“change_interval”:“0”,“cm_calibration”:“60.6”,“bp_altitude”:“0”,“bp_pressure”:“0”,“bp_temp_prec”:“0”,“bp_press_prec”:“0”,“amgt_accel”:“0”,“amgt_mag”:“0”,“amgt_gyro”:“0”,“impact_accel”:“0”,“impact_data_rate”:“4”,“impact_threshold”:25,“impact_duration”:1,“activ_interr_x”:1,“activ_interr_y”:2,“activ_interr_z”:4,“activ_interr_op”:8,“force_calibration_co2_auto_config”:“”,“force_calibration_co2”:400,“filtering”:0,“data_rate”:5,“time_series”:0,“reading_type”:1,“mode_80_active”:“”,“mode_80”:0,“measurement_mode_80_active”:“”,“measurement_mode_80”:0,“on_request_timeout_80_active”:“”,“on_request_timeout_80”:0,“deadband_80_active”:“”,“deadband_80”:0,“filter_80_active”:“”,“filter_80”:0,“output_data_rate_p1_81_active”:“”,“output_data_rate_p1_81”:0,“output_data_rate_p2_81_active”:“”,“output_data_rate_p2_81”:0,“sampling_duration_p1_81_active”:“”,“sampling_duration_p1_81”:0,“sampling_duration_p2_81_active”:“”,“sampling_duration_p2_81”:0,“led_alert_mode_84_active”:“”,“led_alert_mode_84”:0,“led_accelerometer_threshold_84_active”:“”,“led_accelerometer_threshold_84”:“”,“led_velocity_threshold_84_active”:“”,“led_velocity_threshold_84”:“”,“acceleration_interrupt_threshold_84_active”:“”,“acceleration_interrupt_threshold_84”:“”,“set_rtc_101”:0,“current_calibration_82”:“”,“current_calibration_82_active”:false,“output_data_rate_101_active”:“”,“output_data_rate_101”:0,“sampling_duration_101_active”:“”,“sampling_duration_101”:1,“sampling_interval_101_active”:true,“sampling_interval_101”:“0”,“full_scale_range_101_active”:“”,“full_scale_range_101”:1,“x_axis_101”:“”,“y_axis_101”:“”,“z_axis_101”:“”,“low_pass_filter_80_active”:“”,“low_pass_filter_80”:0,“high_pass_filter_80_active”:“”,“high_pass_filter_80”:0,“low_pass_filter_81_p2_active”:“”,“low_pass_filter_81_p2”:0,“high_pass_filter_81_p2_active”:“”,“high_pass_filter_81_p2”:0,“x”:300,“y”:460,“wires”:[[“7bca4492.49843c”,“5f904df8.398294”,“ea7ab3d8.47fb18”,“e6e2f475.d01c68”]]},{“id”:“7bca4492.49843c”,“type”:“split”,“z”:“3fb61b98.1eefbc”,“name”:“”,“splt”:“\n”,“spltType”:“str”,“arraySplt”:1,“arraySpltType”:“len”,“stream”:false,“addname”:“topic”,“x”:470,“y”:460,“wires”:[[“a95a7f0f.98ec3”,“be23f13d.6c6988”]]},{“id”:“a95a7f0f.98ec3”,“type”:“switch”,“z”:“3fb61b98.1eefbc”,“name”:“”,“property”:“topic”,“propertyType”:“msg”,“rules”:[{“t”:“regex”,“v”:“rms_.",“vt”:“str”,“case”:true},{“t”:“regex”,“v”:"max_.”,“vt”:“str”,“case”:true},{“t”:“eq”,“v”:“temperature”,“vt”:“str”},{“t”:“eq”,“v”:“Ext_temperature”,“vt”:“str”},{“t”:“regex”,“v”:“peak_.",“vt”:“str”,“case”:true},{“t”:“regex”,“v”:"current_.”,“vt”:“str”,“case”:true}],“checkall”:“true”,“repair”:false,“outputs”:6,“x”:670,“y”:460,“wires”:[[“96c3de8.2d9452”,“119d4ebb.558581”],[“c4594ecd.ff6798”,“4967a955.5749d”],[“47329949.1939d”,“593264d6.05e1ec”],[“7216e4cd.c936a4”,“871e4961.d9594”],[“70e91d3f.aa3f14”,“8273864.a2dc8f8”],[]]},{“id”:“96c3de8.2d9452”,“type”:“ui_chart”,“z”:“3fb61b98.1eefbc”,“name”:“”,“group”:“a560587f.c8418”,“order”:0,“width”:0,“height”:0,“label”:“RMS”,“chartType”:“line”,“legend”:“false”,“xformat”:“HH:mm:ss”,“interpolate”:“linear”,“nodata”:“”,“dot”:true,“ymin”:“”,“ymax”:“”,“removeOlder”:1,“removeOlderPoints”:“”,“removeOlderUnit”:“3600”,“cutout”:0,“useOneColor”:false,“useUTC”:false,“colors”:[“#1f77b4”,“#aec7e8”,“#ff7f0e”,“#2ca02c”,“#98df8a”,“#d62728”,“#ff9896”,“#9467bd”,“#c5b0d5”],“outputs”:1,“useDifferentColor”:false,“x”:1370,“y”:420,“wires”:[[]]},{“id”:“c4594ecd.ff6798”,“type”:“ui_chart”,“z”:“3fb61b98.1eefbc”,“name”:“”,“group”:“a560587f.c8418”,“order”:0,“width”:0,“height”:0,“label”:“Max”,“chartType”:“line”,“legend”:“false”,“xformat”:“HH:mm:ss”,“interpolate”:“linear”,“nodata”:“”,“dot”:true,“ymin”:“”,“ymax”:“”,“removeOlder”:1,“removeOlderPoints”:“”,“removeOlderUnit”:“3600”,“cutout”:0,“useOneColor”:false,“useUTC”:false,“colors”:[“#1f77b4”,“#aec7e8”,“#ff7f0e”,“#2ca02c”,“#98df8a”,“#d62728”,“#ff9896”,“#9467bd”,“#c5b0d5”],“outputs”:1,“useDifferentColor”:false,“x”:1370,“y”:460,“wires”:[[]]},{“id”:“5f904df8.398294”,“type”:“debug”,“z”:“3fb61b98.1eefbc”,“name”:“”,“active”:true,“tosidebar”:true,“console”:false,“tostatus”:false,“complete”:“true”,“x”:670,“y”:660,“wires”:[]},{“id”:“be23f13d.6c6988”,“type”:“debug”,“z”:“3fb61b98.1eefbc”,“name”:“”,“active”:true,“tosidebar”:true,“console”:false,“tostatus”:false,“complete”:“true”,“x”:660,“y”:600,“wires”:[]},{“id”:“4967a955.5749d”,“type”:“debug”,“z”:“3fb61b98.1eefbc”,“name”:“Max debug”,“active”:true,“tosidebar”:true,“console”:false,“tostatus”:false,“complete”:“true”,“x”:1050,“y”:460,“wires”:[]},{“id”:“119d4ebb.558581”,“type”:“debug”,“z”:“3fb61b98.1eefbc”,“name”:“RMS debug”,“active”:true,“tosidebar”:true,“console”:false,“tostatus”:false,“complete”:“true”,“x”:1050,“y”:420,“wires”:[]},{“id”:“7216e4cd.c936a4”,“type”:“debug”,“z”:“3fb61b98.1eefbc”,“name”:“External Temp Debug”,“active”:true,“tosidebar”:true,“console”:false,“tostatus”:false,“complete”:“true”,“x”:1060,“y”:540,“wires”:[]},{“id”:“47329949.1939d”,“type”:“debug”,“z”:“3fb61b98.1eefbc”,“name”:“Motor Temp debug”,“active”:true,“tosidebar”:false,“console”:false,“tostatus”:false,“complete”:“true”,“x”:1050,“y”:500,“wires”:[]},{“id”:“70e91d3f.aa3f14”,“type”:“debug”,“z”:“3fb61b98.1eefbc”,“name”:“Peak Debug”,“active”:true,“tosidebar”:true,“console”:false,“tostatus”:false,“complete”:“true”,“x”:1030,“y”:580,“wires”:[]},{“id”:“593264d6.05e1ec”,“type”:“ui_gauge”,“z”:“3fb61b98.1eefbc”,“name”:“”,“group”:“33232132.9c903e”,“order”:2,“width”:0,“height”:0,“gtype”:“gage”,“title”:“Motor Temp “,“label”:“Celsius”,“format”:”{{value | number:3}}”,“min”:0,“max”:“100”,“colors”:[“#00b500”,“#e6e600”,“#ca3838”],“seg1”:“”,“seg2”:“”,“x”:1390,“y”:500,“wires”:[]},{“id”:“871e4961.d9594”,“type”:“ui_gauge”,“z”:“3fb61b98.1eefbc”,“name”:“”,“group”:“33232132.9c903e”,“order”:3,“width”:0,“height”:0,“gtype”:“gage”,“title”:“External Temperature”,“label”:“Celsius”,“format”:“{{value | number:4}}”,“min”:0,“max”:“100”,“colors”:[“#00b500”,“#e6e600”,“#ca3838”],“seg1”:“”,“seg2”:“”,“x”:1420,“y”:540,“wires”:[]},{“id”:“8273864.a2dc8f8”,“type”:“ui_chart”,“z”:“3fb61b98.1eefbc”,“name”:“”,“group”:“a560587f.c8418”,“order”:0,“width”:0,“height”:0,“label”:“Peak”,“chartType”:“line”,“legend”:“false”,“xformat”:“HH:mm:ss”,“interpolate”:“linear”,“nodata”:“”,“dot”:true,“ymin”:“”,“ymax”:“”,“removeOlder”:1,“removeOlderPoints”:“10”,“removeOlderUnit”:“3600”,“cutout”:0,“useOneColor”:false,“useUTC”:false,“colors”:[“#1f77b4”,“#aec7e8”,“#ff7f0e”,“#2ca02c”,“#98df8a”,“#d62728”,“#ff9896”,“#9467bd”,“#c5b0d5”],“outputs”:1,“useDifferentColor”:false,“x”:1370,“y”:580,“wires”:[[]]},{“id”:“e6e2f475.d01c68”,“type”:“change”,“z”:“3fb61b98.1eefbc”,“name”:“”,“rules”:[{“t”:“set”,“p”:“payload”,“pt”:“msg”,“to”:“data.battery”,“tot”:“msg”}],“action”:“”,“property”:“”,“from”:“”,“to”:“”,“reg”:false,“x”:680,“y”:740,“wires”:[[“c265b4fb.a3251”]]},{“id”:“c265b4fb.a3251”,“type”:“ui_gauge”,“z”:“3fb61b98.1eefbc”,“name”:“”,“group”:“d1cf38f7.008fb8”,“order”:2,“width”:“12”,“height”:“4”,“gtype”:“gage”,“title”:“Battery”,“label”:“V”,“format”:“{{value | number:2}}”,“min”:0,“max”:“3.3”,“colors”:[“#e00600”,“#e6e600”,“#07ca00”],“seg1”:“”,“seg2”:“”,“x”:900,“y”:740,“wires”:[]},{“id”:“644aaa0a.255344”,“type”:“ui_chart”,“z”:“3fb61b98.1eefbc”,“name”:“”,“group”:“a560587f.c8418”,“order”:1,“width”:“0”,“height”:“0”,“label”:“Current”,“chartType”:“line”,“legend”:“true”,“xformat”:“HH:mm:ss”,“interpolate”:“linear”,“nodata”:“”,“dot”:true,“ymin”:“”,“ymax”:“”,“removeOlder”:“1”,“removeOlderPoints”:“”,“removeOlderUnit”:“86400”,“cutout”:0,“useOneColor”:false,“useUTC”:false,“colors”:[“#00e40f”,“#aec7e8”,“#ff7f0e”,“#2ca02c”,“#98df8a”,“#d62728”,“#ff9896”,“#9467bd”,“#c5b0d5”],“outputs”:1,“useDifferentColor”:false,“x”:900,“y”:860,“wires”:[[]]},{“id”:“ea7ab3d8.47fb18”,“type”:“split”,“z”:“3fb61b98.1eefbc”,“name”:“”,“splt”:“\n”,“spltType”:“str”,“arraySplt”:1,“arraySpltType”:“len”,“stream”:false,“addname”:“topic”,“x”:510,“y”:900,“wires”:[[“2389446f.4ca46c”,“644aaa0a.255344”]]},{“id”:“2389446f.4ca46c”,“type”:“ui_gauge”,“z”:“3fb61b98.1eefbc”,“name”:“”,“group”:“11cd31f6.486afe”,“order”:1,“width”:“12”,“height”:“4”,“gtype”:“gage”,“title”:“Current”,“label”:“Volts”,“format”:“{{value | number:2}}”,“min”:“0”,“max”:“400”,“colors”:[“#403600”,“#d9ca00”,“#ffeb00”],“seg1”:“”,“seg2”:“”,“x”:900,“y”:900,“wires”:[]},{“id”:“837142ce.132b28”,“type”:“ncd-gateway-config”,“z”:“”,“name”:“Edge Dev”,“comm_type”:“serial”,“ip_address”:“”,“tcp_port”:“2101”,“port”:“/dev/ttyS1”,“baudRate”:“115200”,“pan_id”:“7FFF”,“rssi”:true},{“id”:“a560587f.c8418”,“type”:“ui_group”,“z”:“”,“name”:“Default”,“tab”:“77fe301a.bf3d68”,“order”:1,“disp”:false,“width”:“24”,“collapse”:false},{“id”:“33232132.9c903e”,“type”:“ui_group”,“z”:“”,“name”:“Sensor Signal Strength”,“tab”:“8ee481d7.1587”,“order”:1,“disp”:true,“width”:“6”,“collapse”:false},{“id”:“d1cf38f7.008fb8”,“type”:“ui_group”,“z”:“”,“name”:“Thermocouple”,“tab”:“65610a4f.c4789c”,“order”:1,“disp”:false,“width”:“12”,“collapse”:false},{“id”:“11cd31f6.486afe”,“type”:“ui_group”,“z”:“”,“name”:“Thermocouple”,“tab”:“75a6d44a.102d5c”,“order”:1,“disp”:false,“width”:“12”,“collapse”:false},{“id”:“77fe301a.bf3d68”,“type”:“ui_tab”,“z”:“”,“name”:“History”,“icon”:“dashboard”},{“id”:“8ee481d7.1587”,“type”:“ui_tab”,“z”:“”,“name”:“Status”,“icon”:“dashboard”,“disabled”:false,“hidden”:false},{“id”:“65610a4f.c4789c”,“type”:“ui_tab”,“z”:“”,“name”:“Battery”,“icon”:“dashboard”,“disabled”:false,“hidden”:false},{“id”:“75a6d44a.102d5c”,“type”:“ui_tab”,“z”:“”,“name”:“Current”,“icon”:“dashboard”}]
