I wrote code to turn on and off the relay under computer control. I see the lights on the board flink and no errors being generated on the computer. I then tried the same sequences of codes on the COMM Opreator but they do not work either. But turning on and of using ProXR Enhanced Command Set screen works perfectly. I have tried selecting the bank first then send an on command. Combine commads etc. Noting works. If I am sending incorrect codes in COMM operator can you suggest the correct ones to use.
I am using a ProxR LITE with 1 relay with USB interface. See below:
