I have an NCD ADS1115 single input board and can’t get valid readings from the board. I’ve added a NCD power isolator inbetween my photon and the ADS1115 board. I do not have an external power supply connected to my 4-20mA loop.
My configuration is simple, I have a 4-20mA pressure transmitter connected to the two terminals of the ADS1115 input board. When I do not have a transmitter connected, I am receiving -4138 as a reading. If I connect my pressure transmitter to the terminals (no pressure applied, so 0psi = 4mA - verified with a meter) I see 26112.
These readings are being taken using the code provided on github (below for reference).
These readings don’t make any sense because this would be 7562 per mA (which would require a total of 121,000 bits where 0mA is at the -4138 mark and there would therefore be no way to achieve the full 4-20mA range.
Am I doing something wrong? Was I supposed to change a gain value somewhere?
Any help is appreciated!
// Distributed with a free-will license.
// Use it any way you want, profit or free, provided it fits in the licenses of its associated works.
// ADS1115
// This code is designed to work with the ADS1115_I2CADC I2C Mini Module available from ControlEverything.com.
// https://www.controleverything.com/content/Analog-Digital-Converters?sku=ADS1115_I2CADC#tabs-0-product_tabset-2
#include <application.h>
#include <spark_wiring_i2c.h>
// ADS1115 I2C address is 0x48(72)
#define Addr 0x48
int raw_adc = 0;
void setup()
// Set variable
Particle.variable(“i2cdevice”, “ADS1115”);
Particle.variable(“raw_adc”, raw_adc);
// Initialise I2C communication as MASTER
Wire.begin();
// Initialise Serial Communication, set baud rate = 9600
Serial.begin(9600);
// Start I2C Transmission
Wire.beginTransmission(Addr);
// Select configuration register
Wire.write(0x01);
// AINP = AIN0 and AINN = AIN1, +/- 2.048V
Wire.write(0x84);
// Continuous conversion mode, 128 SPS
Wire.write(0x83);
// Stop I2C Transmission
Wire.endTransmission();
delay(300);
void loop()
unsigned int data[2];
// Select data register
Wire.write(0x00);
// Request 2 bytes of data
Wire.requestFrom(Addr, 2);
// Read 2 bytes of data
// raw_adc msb, raw_adc lsb
if (Wire.available() == 2)
data[0] = Wire.read();
data[1] = Wire.read();
// Convert the data
int raw_adc = (data[0] * 256.0) + data[1];
if (raw_adc > 32767)
raw_adc -= 65535;
// Output data to dashboard
Particle.publish(“Digital Value of Analog Input :”, String(raw_adc));
delay(1000);
