Is there any guide to assist in allowing the WiFi Micro Gateway MQTT to connect to a hidden WiFi Network?
Is it possible?
The latest MQTT Gateway firmware has a field for hidden networks. You can update the firmware on your MQTT Gateway by following this guide:
