Hi, I’m using a MirX2X set to relay signal to two 24VDC stacklights and was wondering if the MirX controllers could be powered by the same 24VDC power supply to simplify the installation rather than the 12VDC supplies.
Thanks in advance
Gregg
Thanks in advance
Gregg
Hi Gregg,
Its not possible to power the relay board using 24VDC.
I will recommend looking into a step down power supply like this one
Bhaskar, thanks for the advice. I wish the site had clearer specifications for the power needs and/or had this item in the recommended accessories list.
